delete sshd2 user-key
delete sshd2 user-key key_name
Description
Deletes a user key.
Syntax Description
key_name Specifies the name of the public key to be deleted.
Default
N/A.
Usage Guidelines
This command is used to delete a user key. The key is deleted regardless of whether or not it is bound to a user.
If a user is bound to the key, they are first unbound or unassociated, and then the key is deleted.
The following example shows the SSH user key id_dsa_2048 being deleted:
delete sshd2 user-key id_dsa_2048
This command was first available in ExtremeXOS 12.0.
Platform Availability
